Troubleshooting a DSO 138
watd
Joined Jul 27, 2021
Hi Everyone,
I am new fairly new to building electronics. I have been working on DSO 138 kit and for the life of me can't get it working. I get a voltage going into the first diode by power supply, but then nothing further on board. Have checked components and solder connections to no avail. Has anyone worked with one of these? Any tips?
981DCF66-AD38-4C01-A064-7BEC5B9766C2_1_105_c.jpegA231E5C5-C01E-401B-86BE-7AB4C3CC40C9_1_105_c.jpeg
35,326
Have you soldered before?
It looks like you have used too much solder.
Look for a solder bridge between a solder pad and the ground plane.
dl324
Joined Mar 30, 2015
18,524
Make sure D2 is installed correctly. Then check the solder joint on the cathode. If that checks out, remove power from the circuit and check the resistance from TP20 to ground.
watd
Joined Jul 27, 2021
Thanks, will check D2.
I am still working on my soldering technique, so yeah it is a little excessive. I have checked for bridges, but don't seem to see any.
Appreciate the suggestions.
