Triode tube
Rufinus
Joined Apr 29, 2020
324
Hello. I'm going to make a triode tube. The question is I don't have idea about how to test it. I mean, how much voltage do I have to apply between cathode and anode and in the grid.
Of course it's depend on the construction of the tube, but I'd like to know between what values I should move.
Thank you
Best regards
Rufinus
Joined Apr 29, 2020
324
There are quite a few utube videos on making and testing your own tubes.
Yes, I have seen these videos. In youtube for example jdflyback and glasslinger, but besides they explain veeeery well how to make the tube, when they test the tubes, they don´t explain too much. Just some needles moving, confirming that the tube works, but nothing avout voltages and currents.
Do you have a device in mind for the use of your triode?
Not for this first one. Jus making a tube. In the future, I´d like to make a radio
Why not? I like to make things
I asked the question why because the design (voltage, gain, frequency response, etc...) of the tube depends on its intended usage. You can design 'space-charge' tube that operate at 12 volts or shunt regulators that operate at thousands. So your initial question was far too broad for a proper answer. If you have the proper vacuum apparatus, making a tube is trivial, it's making the tube that's a challenge.
What's your experience level with tube circuits?
Rufinus
Joined Apr 29, 2020
324
Was just reading the wiki, very interesting. Powering the tube
Thank you, there are some values in the article.
Take a look @ WorldRadioHistory: Radio Music Electronics Publications ALL FREE. It has many old books both cataloging tubes and on their design.
Thank you!! there are a lot of maerial, it will be useful for the radio project also.
Ah ok, sorry, I´m still learning english. Ok I don´t have any experience
35,193
Sure, you can build a radio using a vacuum tube. But why bother when a FET can do the same thing as a tube.
Here is my circuit for a simple radio using a FET as an RF amplifier. Buena suerte!
Rufinus
Joined Apr 29, 2020
324
Here is how you test it:
Get two power supplies, 0 to 150V and 0 to -10V and a mA meter.
Setting grid voltages of 0, -1, -2 etc. Sweep the anode voltage from 0 to 150V, taking current readings and plotting a set of curves like this:
12AX7 characteristic curves
Thank you!
It is not about the destiny but about the journey. I like making things from 0
35,193
