Trigger a microwave "Beep" sound
ThomCircuit
Joined Feb 4, 2020
45
Hi and thank you.
I've got a latching touch sensor component that triggers a relay which turns on some lights. The sensors trigger is 5v. I've connected the sensor to a decorative metal plate via a copper wire. I've drilled a 5mm hole in the plate and inserted a dual blue/red led. The led is always illuminated until the plate is touched changing the color to blue. I used an NGATE to work out that logic. My final task is to make it "beep" each time it is pressed. Browsing this forum I ran across this edge decter circuit. I need a bit of help adapting this to my project. It only needs to produce the beep. I have identified all the components except for the type of speaker. Active,passive,magnetic? I just can't figure that out.
I should mention that I knew nothing about circuits until 4 weeks ago so please excuse my lingo. I hope I've provided enough info. Thank you.
SamR
Joined Mar 19, 2019
5,539
Passive speakers require a frequency input to make sound while active only require voltage and generate their own frequency.
ThomCircuit
Joined Feb 4, 2020
45
Can you tell me what type of speaker is in this circuit? From what I read it appears to be active. I am not familiar with what a passive piezo sounds like does it make a beep sound like that in a microwave oven or is more of a mechanical sound
SamR
Joined Mar 19, 2019
5,539
Passive will not make noise unless you supply it with one. To generate sound with simple ON/OFF voltage you want an active speaker that generates its own sound frequency. Different manufactured active speakers will make different sounds. Typically a monotone buzzer sound of different tonal frequencies from very high to very low. The "Ting" bell-like sound of a microwave is probably generated by a sound chip and played to a passive speaker. The keyword on the schematic is Annunciator which is an active speaker/buzzer.
cmartinez
Joined Jan 17, 2007
8,867
