Triac control LED bulb flickering
LOTUS_RATHOD
Joined Aug 23, 2019
8
Hi i am Lotus,
I make circuit of triac AC load control (on and off only) see attached file
I have some few question related to TRIAC control.
1. When I connect filament bulb then it's working fine but when connect LED bulb then bulb is flickering. I know because of latching current and holding current of triac but my question is how to remove it.
2. If i remove R3 and C1 then LED bulb is not flickering. Why ? and How?
3. Which type of resistor and capacitor can be use for snubber circuit (R3 and C1)? i want it SMD small size packeg.
LOTUS_RATHOD
Joined Aug 23, 2019
8
Thank you for replay DickCappels and danadak
The LED bulb is non-dimmeble and its have in built voltage down converter for small LEDs
Dodgydave
Joined Jun 22, 2012
11,307
You need a 1K resistor between G and MT1, to keep the gate off..Also put the load in the MT2 circuit series Live.
omit the R3,C1..
LOTUS_RATHOD
Joined Aug 23, 2019
8
Dear Dodgydave and other my friends
Thank you for your advice but I can't remove R3 and C1 from circuit because of it's block high voltage and current transient.
And if i connect filament bulb then that transient will turn on the bulb for some milliseconds. So can't remove it.
I connect 1K resistor as you told. But LED bulb still blinking. I think it's blink because of R3 and C1 component.And when i remove R3 and C1 then LED bulb not blinking and work fine.May be i need to change R3 and C1 value.
ci139
Joined Jul 11, 2016
1,898
the link is to get there , the attached .txt contains the sim. to drop to Menu/File/Import From Text
the sim. showed that 9W "current lim" enables the triac to switch on near max amplitude + it'll produce a lot of heat with low loads ...
however with some modifications i now got the thing to simulate ...
LOTUS_RATHOD
Joined Aug 23, 2019
8
Dear ci139 thanks for the support.
I see the sim file and I have some doubts.
1. what is the op-amp and D flip-flop circuit do.
2. how you say " it produce lot of heat " I check with hardware and any component not get hot.
3. In practical when i remove snubber circuit then LED bulb not blink but in your simulation shown some current will flow in TRIAC after 100nF capacitor remove.Why ?
4. and my biggest question how to solve it ?(flickering of LED bulb) still didn't get it :(
And Please help me to select snubber circuit resistor and capacitor type.(i want to use SMD packeg).
Please Help Me :(:confused:
