Tri color LED
CFD
Joined Aug 31, 2023
Years ago, I had a 2 lead LED that would be green with one polarity of DC, red with the polarity reversed and yellow with AC volts. I can't find these anymore. Are they no longer made? I have seen LED's with 4 leads that are multi colored, but not the kind I had.
dl324
Joined Mar 30, 2015
18,447
Welcome to AAC
Jameco has them. Should be readily available from multiple sources. eBay came up, but I wouldn't buy there if you need to know the specs. Jameco has datasheets for just about everything they sell.
You may have had problems finding them because you called them tri-color and they're bi-color.
schmitt trigger
Joined Jul 12, 2010
2,173
Same experience with the ambiguous yellow color.
One must have different resistance values for the forward and reverse current, to equalize their unequal brightness.
dl324
Joined Mar 30, 2015
18,447
Doesn't the red and green (primary light colors) mix to form yellow?
It depends on the relative brightness of the red and green LEDs and the duty cycles for red and green.
From the datasheet for the 3mm LED I referenced:
You can see that the red green LED is more than twice as bright as the green red.
EDIT: corrected colors, old bias
Ian0
Joined Aug 7, 2020
13,227
Red and green can be mixed to make any colour between red and green. If they are in equal quantities you get yellow. Slightly more red and you get orange.
BobTPH
Joined Jun 5, 2013
11,609
If you have ever tried mixing to get yellow, you would understand. The color only looks yellow in a very narrow range of ratios.
Audioguru again
Joined Oct 21, 2019
6,826
You can see that the red LED is more than twice as bright as the green.
No, the The green LED produces a brightness of typically 5mcd but the red produces typically only 2mcd.
In the olden days, a red and green LED produced almost the same brightness but modern green LEDs are much brighter than the old ones.
