I have a treadmill where the motor-speed controller is going bad.
I was wondering what people think i should look at first. The symptoms are as follows:
power/controller board successfully continues to work as motor-speed increases. the motor-speed controller board's "SRC TRIG" LED keeps "blinking" and the motor keeps turning UNTIL about "2mph" is on the display. the motor just stops and the blinking LED dies out. 3 wires connect from the power/controller board, so can i assume its a pwm sigmal to control the 4-wire DC motor?
the LED's on the power/controller board still "blink" the same and the display goes down to "0mph" because the magnetic-reed switch for speed is now longer getting input--if i turn motor manually the display shows an "mph" of me activating the magnetic-reed switch..
i'm attaching a pic of the board... the IC's are (2) LM324N's and there are three T220 "D1..3" and two T220 "Q1..2" attached to the huge-heatsink.
I'm assuming a resistor broke down and the LM324's are not comparing the speed of the motor correctly. could it possibly be a bad DC motor's speed-sensor? I thought of opening up the DC motor, but i can't imagine that sensor going bad.... am i wrong? the "current limit" LED never turns on
any help please.... ?
