Well, the high end controllers certainly have some sort of smartness. For example, I ended up building my own motor controller using a software PI controller and a hall effect sensor for feedback. It's not as easy as it seems from the first insight.The motor will need to keep its RPM under load, ie running on the belt, I assume this circuit is not that smart?
Hi sir good day im new here,,sir i have a problem related this i cant find with the is the best pwm diy circuit to control treadmill motorWould this one do For 240vac and 160v motor? I too have a treadmill with a blown board A lot cheaper and current 10A max 10A?
MOD NOTE: Split from another thread.
by Dale Wilson
