- Joined Jul 18, 2013
- 30,713
Lamp Wattage?I didn't but I actually bought a flood light the other day.
Great idea thanks max, I'll try that in a while and report back. Thanks for your help by the way, it's very kind of you.That should be OK.
You could also carefully check the voltage across the lamp when the power is applied to see if you notice any ramp up.
Hey Max just tried it and it blew bulb straight away, no ring or anything seems like a surge of power when start is hitThat should be OK.
Shall I replace the Mosfet altogether? Only a few bucks. What mosfet should I get?So what could be happening is that you are getting full voltage with no ramp up, the Processor detected over current and shut down, the load of the lamp was not enough to blow the fuse.
This would be my guess.
Points to the Mosfet as a possibility.
Actually i see it is a IGBT, not a Mosfet as usually fitted.
Might pay to remove it from circuit and test for short circuit, test on resistance range, not the diode range.
Ah ok I got ya, I live in Ireland, checked Digikey Ireland website with the part number but says no stock obslete Item. Would I be able to grab one off eBay?If in doubt, I would replace it, it is a IGBT not a Mosfet, BTW.
Where are you located? I use Digikey if they have stock.
The full part No is IRG4PC40KDE206P
Awesome thanks man i got the sub oneYou could try ebay or use a sub such as HGTG30N60A4
No they didnt have it, non stock it said so the sub will be fine anyway no? The place i got it from is based in dublin so post will be fast tooBut RS also had the original??
Hmm good thinking, it only blows when a motor is connected. However the lamp test it did not get gradually brighter. Just a large flash then nothing but no fuse blown.I just realized something, that if the fuse does not blow until the start is hit and not right away at switch on, it could possibly be the SCR, the smaller device on the H.S.
This ramps up the power slowly when a start is issued.
In addition to the above when the board is powered I notice a high pitch whine I believe it's from this. The yellow device.I just realized something, that if the fuse does not blow until the start is hit and not right away at switch on, it could possibly be the SCR, the smaller device on the H.S.
Yeah it's baffling only blows when motor is connected and it won't keep the lamp illuminatedThat transformer appears to be the low voltage transformer for the 12v-15vdc you can measure this on pins 1 & 2 of HD2.
If the fuse only blows when you initiate a start then it could be the SCR circuit, the small device next to the large bridge rect. on the heat sink.
If it blow at power up before a start, then it points to the IGBT.
You may be getting the 2 blinks as the controller is not seeing the belt signal when testing with a lamp.
Does Not blow at power up.But still not clear, blows at power up? or only when command issued?
