MaxHeadRoom
- Joined Jul 18, 2013
- 30,885
Then that would appear to point to the SCR or its circuit rather than the IGBT/Mosfet, which if shorted, should blow right away at power up.
The programmed speed command is given to the IGBT when Start is issued, but the power is ramped up with the SCR, which if shorted, would place full voltage on the motor and likely be the cause of the fuse blowing.
Max..
Max..
