It doesn't matter if there is one or two supplies.
The point is, the base current has to come from somewhere. It doesn't matter where the base supply is referenced.
For educational illustration, it is common to show the base current coming from a separate voltage source.
In most circuit applications, the base current is supplied by some node in the circuit. There is not usually a separate supply to provide the base current.
