transistors out of saturation in an op amp
jsnx
Joined Mar 17, 2022
21
Hello, what would happen if, in my operational amplifier, some transistors are not in saturation at a certain input voltage? I find it quite hard, nearly impossible, to maintain tall the transistors in the saturation region for every input voltage, some of my transistors leave the saturation region when I have a -2V voltage in the inputs.
Papabravo
Joined Feb 24, 2006
22,116
What makes you think the transistors need to be in saturation?
Audioguru again
Joined Oct 21, 2019
6,826
Jsnx did not show a schematic with parts values.
With the input at -2V, the supply is +10V and -10V and the gain of the opamp is set at 1 then the output will be not saturated at +2V or -2V.
With the input at -2V, the supply is +10V and -10V and the gain of the opamp is set at 1000 then the output will be saturated at a positive or negative voltage as high as it can go.
Maybe he is talking about Mosfet transistors that are linear when saturated.
Papabravo
Joined Feb 24, 2006
22,116
Was the TS talking about the output transistors or all of the transistors?
