Transistor with minimum Rdson at 200V
Motanache
Joined Mar 2, 2015
652
What transistor should I use?
I did an audio amplifier, but the joy was short.
At the final stage it has an IR2110 driver.
I used the IRF840 and I noticed they're getting hot enough.Ddson=0.8ohms.
In is without heat sink and I do not have Gate resistor.
Then I replaced with sk2134 Rdson=0.4ohms.
And heat less, but they still get warm.
IRFP150 has Rdson=50mohms, but it has 100V maximum.
I did not understand why at next, IRFP240 Rdson does not double but increases unexpectedly.
If the power source used for the amplifier (step-up) is faulty It can give up to 200V(+/-100V).
