I have a standard 2N4401 transistor.
a low voltage input on the Base pin.
Emitter pin to ground.
and a 15~20V input on the Collector pin with a load.
I have a 500mA draw from this circuit.
upon removing the transistor and applying the 15~20V directly to the load, I have 2A draw.
I want as much current as possible to my load. What kind of transistor can I use?
I need a transistor that can take high voltage input
(up to 100-200V and let up to 5A pass)
