transistor req help
markosillypig
Joined Jul 21, 2008
188
h i am making this circuit i have altered it from the original one could any one tell me that i could use as Q1 to Q10 for 500 MA or above say 750MA and what the value of resistors i need for the Q1 to Q10
thanks
mik3
Joined Feb 4, 2008
4,843
The maximum output current of U2 when it is power with 5V is 0.36 mA. Thus you will need a 12K resistor for each transistor. Also, you have to use darlington transistors which have a gain greater than 1500 at saturation.
mik3
Joined Feb 4, 2008
4,843
The IRF530 is not a logic level MOS. It needs 10V to fully turn on however you may use it because the current through it will be only 500mA. Try one and if it gets very hot then you have to use another one or power U2 with 10V.
I can't find TIP23.
hgmjr
Joined Jan 28, 2005
9,027
You are going to need to use a different regulator than the 78L08 since it is only rated for 100 milliamps maximum.
hgmjr
22,101
Yeah. I see 5 amps through the total of 10 transistors. You do realize that (15V-5)*5A = 50 Watts. You will need atl east a TO-3 package and one whale of a heatsink to dissipate 50 Watts or you will cook the regulator.
BTW a TIP120 is a TO-220 NPN Darlington
SgtWookie
Joined Jul 17, 2007
22,230
Marko,
You'd be better off using MOSFETs.
Order some of these IRLD014's: http://www.mouser.com/ProductDetail...=sGAEpiMZZMveMCOqFR6qCPeAjNEHCd78YZDGJGvck3Y=
[eta] Actually, Jameco is considerably less expensive: http://www.jameco.com/webapp/wcs/st...amecoall&ddkey=http:StoreCatalogDrillDownView
Get some extra. They're logic-level N-channel MOSFETs rated for 60v 1.7A in a 4-pin DIP package; really slick. You will use them for lots of projects.
The 78L08 won't work, as has already been mentioned. A 7808 might, but will require at least 2v higher input.
D1 is a 1N4148; those are rated for 100mA maximum. At 500mA, it would have a very short life indeed (maybe about 5 seconds) before it turned into a miniature volcano. A 1N4000 series or 1N5400 series rectifier diode would last far longer.
You are not showing Vdd and GND connections for the 4017.
You don't show a 0.1uF cap across the power/GND pins of the 555 and the 4017. Don't forget them.
In the lower right corner, you have connected your 7808 output to GND. I'm sure you didn't mean to abuse your regulator in that fashion.
22,101
@Sarge. As I recollect a Johnson Counter aka a twisted ring counter does in fact have a state where all outputs are on and another state where all outputs are off. The lengthof the sequence is 2*n where n is the number of stages. Isn't that right?
SgtWookie
Joined Jul 17, 2007
22,230
Papabravo,
The 4017 is a 5-stage Johnson counter that only has one output (Q0-Q9) high at any given time. If desired, an early reset can be triggered by bringing the reset input high - but no, this particular counter will never have more than one output driven high at a time.
