Transistor or other Device that's "Always On"
Dan-O
Joined Jul 26, 2009
38
The FET would be driving an OEM relay.
This thread went all over the place and I wanted to be sure since the suggestions being posted were using relays and I want to eliminate the relays from my project.
A JFET (not a standard FET or MOSFET - try a J112 for size) will pass maximum current with zero gate bias; use negative voltage to turn it off. They're very handy get-out-of-jail-free cards for circuits where turnon is passive and turnoff is active.
KMoffett
Joined Dec 19, 2007
2,918
I don't recall you ever saying how much current the devices you want to replace the relay(s?) with need to pass.
Ken
Dan-O
Joined Jul 26, 2009
38
I need to measure it to be sure, but it's driving a standard issue automotive relay, probably no more than 200mA
My project will piggy back the OEM stuff so all my circuits are doing is activating the original equipment relays.
CDRIVE
Joined Jul 1, 2008
2,219
Well, if that's the case, the circuit that Sgt. Wookie gave you is perfect! The relay that he shows in his circuit (connected to the Drain) would be your OEM relay.
On the other hand, some circuits in automobiles have the +12V side hard wired to the device, including relays. The circuit is powered by swiching the neg terminal to GND. If that's the case then the N Channel FET schematic that I posted should work. In that case, the relay that I show would be your OEM relay.
CDRIVE
Joined Jul 1, 2008
2,219
They do. The normally closed contact are known as FORM B contact.
Here is a link to the Omron pdf on those relays:
Ah, that's why (if I'm not certain) I always say "That I know of". An old Canadian expression ...CYA. :rolleyes:
BTW, the little SSRs that you posted would be much better suited for what Dano needs to drive than the 20A monster that I posted. I had drawn that schematic prior to realizing that Dano only wanted to drive OEM relays. ;)
Dan-O
Joined Jul 26, 2009
38
Excellent ideas. Keep 'em coming!
I had a duh moment.
I never thought to look for a NC solid state relay.
The $20 cost might be prohibitive for this little project, but that was a great idea.
I'll do more digging.
Thanks everyone for being patient with an amateur.
CDRIVE
Joined Jul 1, 2008
2,219
Just check the current draw on the OEM relays that you're going to control to make sure that they don't exceed the rating of the SSRs. Doubtful though.
