I am building a circuit to control the indicator lights on a automobile. I am using a PIC microcontroller (+5v power) for the control and need to use something to turn on the cars indicators based on the output of the microcontroller. Car's indicators are 12v and draw a total of 1.75A per side.
I was planning on using a npn transistor (TIP122) as the switch controlled by the microcontroller, but here is my problem: Down stream of the tranistor is a relay(s). The relays are there to allow the indicator to override the brake lights when the brake lights are on and the indicator is turned on. I can not put a diode between the relay's coil, as I understand is normally required to eliminate voltage spikes.
I know I could use a transistor to operate a relay instead of only using a higher rated transistor. I would prefer to avoid using relays in the circuit to cut down on the size and improve longevity.
Any suggestions on how I could protect the circuit from voltage spikes if I can't put a diode between the relay's coil? Any other suggestions on solid state switching methods to be used in conjunction with a microcontroller for this application?
Thank you.
JG
Thank you.
JG
