Transistor H-Bridge overheating, what to consider?
CranberryJuice
Joined Dec 22, 2015
8
38,772
You are entirely wrong with your suggestion.
Changing the transistors produces "shoot-through" and you don't know the speed of the incoming signal. Sometimes you have to sacrifice some losses to prevent the bridge blowing up.
You need to ask a lot more questions before suggesting a solution.
Thanks (not really again) for your suggestion but I will continue to answer questions as I see fit and you can do the same.
Don't presume to know what I do or do not know.
