Transistor Calculations
Toshinatrix
Joined Jan 21, 2010
3
Hi
Basically I have been toying around with my electronics homework (which is one of my weaker subjects) and I have become stumped, I'l post a link of the circuit I am looking at further down.
Basically the question asks: Calculate the Power Loss in Transistor T
Information given:
R1 = 400 ohms
R2 = 500 ohms
R3 = 50 ohms
E = 10v
Vbe = 0.6v
Hfe = 10
A formula I have worked out is(although not sure if correct):
E= (Ir1xR1) + Vbe + (IeR3)..... where Ir1 = (Ib + Ir2)
Basically I have been struggling with the initial phase of calculations this, ie.... E, Ib, Ir2, Ir1,
I think if i had a formula to work out those then maybe I could get it.
Thanks for taking the time to read this!
Jony130
Joined Feb 17, 2009
5,601
Solve this
E-I1*R1-I2*R2=0
I1=Ib+I2
I2*R2-Vbe-Ie*R3=0
Ie=(hfe+1)*Ib
Or use the Thévenin
Et=E*R2/(R1+R2)=5.5V
Rth=R1||R2=222Ω
And then
Ie=(Et-Vbe)/(Rb/(hfe+1)+R3=4.9V/70.18Ω=69.81mA
Toshinatrix
Joined Jan 21, 2010
3
Solve this
E-I1*R1-I2*R2=0
I1=Ib+I2
I2*R2-Vbe-Ie*R3=0
Ie=(hfe+1)*Ib
Or use the Thévenin
Rth=R1||R2=222Ω
And then
Soo from what I can get from this I can use thevenins to work out Ie, and from there Ib can be solved using ib= (hfe+1)/Ie and from there I should be able to work my way through it?
slightly disappointed I didnt spot the thevenins way
Thanks for the help
Toshinatrix
Joined Jan 21, 2010
3
Solve this
E-I1*R1-I2*R2=0
I1=Ib+I2
I2*R2-Vbe-Ie*R3=0
Ie=(hfe+1)*Ib
Or use the Thévenin
Rth=R1||R2=222Ω
And then
Hi, the teacher has asked for us to use the formula:
Ptot = Pc + Pb
therefore I have used:
Ie=(Et-Vbe)/(Rb/(hfe+1)+R3=4.95V/70.18Ω=70.5mA
I then used:
Ib = Ie / (hfe +1) = 6.5mA
Therefore Ic = Ie - Ib = 64mA
Vce = E - Ib(hfe+1)R3 = 6.425v
Pb = Ib*Vbe = 3.9mW
Pc = Ic*Vce = 411.2mW
Therefore Ptot = 415.1mW
Could you check through this working and see what you think please?
