If R8 is 10k, then Ie≈ Ic=(3V-2.4V)/10k=60uA. 0.52V Vbe for Ie=60uA is very believable.Ah ha, mystery solved!
The mouser part description is incorrect (here)
It is in fact an NPN after all.
I am curious about the Vbe being just 0.52v (I had expected closer to 0.7v)? Does that seem right?
Low Vgs(th) does not necessarily imply low ON resistance. What you need is a MOSFET which can sustain 700mA at Vds≈1V without requiring high Vgs. This calls for a device with low Vgs(th) AND reasonably low Rds(on) while Vgs is low.Many thanks, I now understand this circuit much better.
I've tried a 470 ohm resistor (instead of 10k). This does increase the Vbe to about 0.57v.
I completely agree, I need a MOSFET with a lower Vgs(th) to ensure it can be sufficiently on to have insignificant resistance.
I find it interesting that Vbe can be lower than 0.7v. While it does mean there is more heat to be dissipated by the MOSFET for any given battery voltage, it also means that the circuit can run to a lower battery voltage (hence run longer).
Any idea if there is likely to be consistency in the NPN Vbe at such low current levels?
The percentage change per degree is greater when Vbe is lower.Thanks Ron.
So do you mean that as the circuit heats up, Vbe would drop more quickly (than if it started higher)? This could actually be desirable to protect the circuit from overhearing if I can tailor the parameters correctly.
