Transistor as a switch
Wendy
Joined Mar 24, 2008
23,869
As a general (very general, lots of exceptions) rule of thumb the emitter is grounded, so the base to emitter current (which turns the transistor on/off) doesn't get involved. The collector/emitter turns on/off, but you have to be carefull it doesn't enter its linear region.
sportsfan27
Joined Jan 29, 2009
43
What I'd like to happen is have a microcontroller turn on the transistors every couple of seconds. The transistors will act as a switch for several LEDs.
mik3
Joined Feb 4, 2008
4,843
Use NPN transistors, with their emitter at ground, a resistor (about 1K) between the base and the microcontroller and your load between the collector and Vcc.
sportsfan27
Joined Jan 29, 2009
43
That's exactly the circuit I have. I don't think I was clear enough, though; my question should have been, how do I program the microcontroller to turn the transistor on and off?
SgtWookie
Joined Jul 17, 2007
22,230
Set the pins you're using to output.
Set the pin to a logic high (1) to turn the transistor on.
Waste some time in a delay loop.
Set the pin to a logic low (0) to turn the transistor off.
Repeat
mik3
Joined Feb 4, 2008
4,843
I quite disagree with Sgt to waist time in a loop. You can set the particular output to 1, make some other calculations with the uC and then set the output to 0 if desired.
hgmjr
Joined Jan 28, 2005
9,027
Perhaps you would be interested in reading up on the use of a transistor as a switch. The link I have provided takes you to the section on transistors operated as switches. It will provide with some background info so that you will better appreciate the other comments your post has garnered.
hgmjr
thatoneguy
Joined Feb 19, 2009
6,359
While very true, what should the uC be calculating if it's entire function in life is to blink LEDs on and off?
Getting philosophical, I suppose the uC may be more eager to blink the LED if he also gets to calculate 1000 digits of pi, followed by 1000 digits of e, but in the end, it is all wasting cycles, since the results can't be displayed. Unless the silicological portion of the "id" is somehow boosted, causing the now happy and confident uC to use less power.
SgtWookie
Joined Jul 17, 2007
22,230
Mik3,
My suggestion was IAW the "KISS" principle. ;)
Sure, I could've suggested that our OP utilize an interrupt when timer0 or timer1 overflowed and increment a counter, disabling and re-enabling the interrupt during the service routine, but for this simple exercise such would be rather bewildering for a "n00b".
As it is, just coding delay loops in assembler can be intimidating.
