Hello. Let's say you have a antenna leading into a parrell lc circuit and from the lc circuit the current leads to a non transistor with a base turn on amps at three amps for current to flow from collector to emitter or a lc circuit in series with a non transistor after the lc circuit with a base turn voltage of 3 volts.
Will the tank circuit resonate amps ( parrelle) or resonate volts (series) until it reaches the volts or amps to turn on the transistor even if it's millivolts or milliamps input from the antenna.
And if this is so once the base voltage or amps are meet to turn the transistor on will it draw three volts or amps from the tank circuit leaving less than three volts or amps in the tank circuit or will the resonance keep a constant three volts or amps flowing through the transistor. Thanks.
