Transformer type?
MaxHeadRoom
Joined Jul 18, 2013
30,662
Appears to be a simple 50hz/60hz mains transformer, with secondary voltage at whatever the bulb is rated for.
I would guess around 60Va?
Measure winding resistance to determine input winding.
Max.
gokush
Joined Oct 8, 2019
9
There is no denote on it but it's easy to identify which one is primary winding because it is connected to fork. Is it possible to determine its coefficient without using oscillograph?
jpanhalt
Joined Jan 18, 2008
11,087
You seem to be asking about two different transformers of greatly different physical sizes. Which one are you interested in? If both, call one Trans1 and the other Trans2 (or similar) to be clear.
gokush
Joined Oct 8, 2019
9
isnt it shown as an independent post?
SamR
Joined Mar 19, 2019
5,491
i cant count number of coils
Why would you want to? You are not building/winding a xfmr. You have the Vi and Vo and to use the xfmr that is all you need? I would suggest using some sort of isolation in front of the xfmr and an input fuse or even put it on a GFI.
gokush
Joined Oct 8, 2019
9
that was an idea to just plug it into GFL and then measure signal coming from secondary winding using oscillograph but I don't have one in my house :D
jpanhalt
Joined Jan 18, 2008
11,087
It is a distinct in the same thread as Transformer1 question.
After your first post, MaxHR asked a question, then your next post was, "There is no denote on it but it's easy to identify..." With a totally different picture attached. Reasonable to assume the "it" refers to your first picture/transformer and the subject of MaxHR's question.
If it is too much effort to be clear, never mind.
gokush
Joined Oct 8, 2019
9
that's my bad sorry about that I was using my phone while posting and I thought that I created this as a new thread :(
You ask about one particular device then switch to another with the same reference?
What is Fork?
Beginning to look like shades of Alchemy One under a different Name!:eek:
Max.
lool I mean plug :D in my country we are using its Russian name "vilka" so I directly translated it into English
