Chinese DIY 0-30V 0.2-3A Power Supply Transformer type?
Irving
Joined Jan 30, 2016
5,195
Welcome to AAC.
To meet spec (such as they are) you'll need 28 or 30v ac or 15-0-15v ac secondary, 90-100VA ('100W') rated. You can get them on eBay for around £60.
Farnell have a 100va 30v ac x 2 toroidal transformer for £61 (part # 4209595 )
But why? This is an old and problematic design.
prairiemystic
Joined Jun 5, 2018
446
I wouldn't use the maximum rated voltage/current transformer with these boards. They are overrated of course.
At less, they work fine, given the price of the kit (all parts and PCB) can go for $5. Just need to add transformer, heatsink/fan etc.
A 25VAC transformer at 50VA might be a better power rating, or a hi/low switch.
edit: TL081 max. is 36V rail with gives around 27VAC max.
irobbie
Joined Apr 29, 2025
12
Welcome to AAC.
Thank you,starting electronics after 35 year layoff, I think this ideal to play around with,
thanks I’ll try that..
prairiemystic
Joined Jun 5, 2018
446
After 46 years, that circuit has not been beaten, in terms of simplicity and cost. The original design I trace back to Practical Electronics Oct. 1978 pg. 40. I know it's not a perfect power supply board but is "good enough" for many applications and china offers the copy for dirt cheap.
That original article might help with your build - but keep in mind the chinese kit uses newer IC's (TL081 verses LM741) that can't quite take as much voltage, so the transformer should be at most around 25VAC IMHO. The original article recommends a 20-25VAC, 2A transformer (based on the pass transistor's limits).
irobbie
Joined Apr 29, 2025
12
Thank you, my ideas are to play around with that board, to help me get back into electronics.
