I believe I understand...Each winding is a phase unto itself, not the fabricated center tap. By measuring from the center tap, you confused yourself by measuring the lower winding backwards.
As far as I know, "read the label" (the dots) or "measure the voltage" are your choices. After all, you just tried to do it with an oscilloscope and got confused. I say lower your standards and just measure the voltage, but then, I'm a very pragmatic person. I only care if it works. What you call it is your business. "In phase", "out of phase"...meh. Just measure the voltage.Is there any other way to find out?
Thank you, going forward when confronted with a transformer without the dots indicated I will measure as indicated as this seems to be the easiest method practically.As far as I know, "read the label" (the dots) or "measure the voltage" are your choices. After all, you just tried to do it with an oscilloscope and got confused. I say lower your standards and just measure the voltage, but then, I'm a very pragmatic person. I only care if it works. What you call it is your business. "In phase", "out of phase"...meh. Just measure the voltage.![]()
I having trouble understanding this. I read the following:The primary and secondary are isolated so there is no concern about phasing relationship between them, only with windings on either primary OR secondary.
http://www.electronics-tutorials.ws/transformer/transformer-construction.htmlThen the construction of a transformer can be such that the secondary voltage may be either "in-phase" or "out-of-phase" with respect to the primary voltage. In transformers which have a number of different secondary windings, each of which is electrically isolated from each other it is important to know the dot polarity of the secondary windings so that they can be connected together in series-aiding (secondary voltage is summed) or series-opposing (the secondary voltage is the difference) configurations.
http://www.radioworld.com/article/working-with-transformers-keep-an-eye-on-phase/1402Notice in the drawing that the phasing dots on the secondaries are at leads I and L. If the primaries of the two transformers are configured and the input voltage applied identically, then the voltage at the secondaries will be identical hence "in phase" at leads I and L.
I see, so even though the dots indicate "which end of each winding is which, relative to the other winding(s)" 1 [secondary winding end relative to the primary winding end], we don't need to worry about the primary when connecting the secondary's in series-aiding. We would therefore use the dots on the secondary to aid us when we connect the secondary's in a series-aiding configuration.The only time the primary phasing matters is when you have (2) transformers. Then, it is nice to have everything orderly. When you only have one transformer, the phase of a secondary winding only matters to which other winding you connect it to. There are situations when you attach a secondary to the primary, and then primary phase matters. Otherwise, ignore it.
This would be for practical reasons. The power supply that I am building will have +/-12V output. When the transformer is at 120V [Black-White] the output on the smaller secondary is 10.58V at no load. I think after full wave rectification, regulator drop out, and transformer ESR it will be too low to get 12V regulated [or I will be cutting it very close].Transformers on the whole are pretty rugged devices, but is this an academic question? as if you have 120v available, why not use the correct winding?
Using 120 on the 100v winding will also mean you would not be able to use the TFMR at the rated VA.
Max.
You can get a reasonable idea of the VA rating of the transformer from its weight. See post #36 in this thread:I do not know what the rated VA is of this transformer. One post earlier indicated that I might be able to get 4 to 5 amps from it. (Perhaps this was referring to when it was run at 120V [Black-White]
Looking at the attached picture, when run at 120V [Red-White] how many amps do you think I would be able to get from the blue-blue coil, and the orange-orange coil?
The transformer I have is the E I type. As I am not familiar with the process of modifying the winding I decided not to go that route at this time.I have the formula somewhere, the desired % ripple for cap selection depends on what % ripple you are want for a given load current.
If you aim for to low a %, using a large capacitance, it will have an effect on your transformer VA requirement.
The higher the voltage for a given % ripple, the capacitance is lower.
Have you considered the overwind option?
All you need to do is obtain magnet or enamel wire, it is a little more tedious with E I transformers, this is one reason that Toroidal types are very popular, they can be modified very easily by either adding or subtracting turns.
Max.
