Transformer connections confused
Kskinky8
Joined Jun 16, 2015
13
Hi thank you for everybody's help so I put 12ac in by the blue and red and got the following ,blue -yellow=24
Blue and black=142
Black and yellow=170
So if I put 24v in I'll get my desired output , but why does it have two large outputs ore whil it stay the same if I put 24v ac in and also how does one flip 24vdc to 24v ac ? Hence I wanna make an inverter out of it
Reloadron
Joined Jan 15, 2015
7,926
Blue and black=142
One could Google for example "Inverter Circuits" and find dozens of circuits similar to this one. The original circuit likely used 24 VDC. Around where I am at it's easier and less expensive to buy than build inverters, especially high power units.
Ron
djb
Joined May 17, 2008
33
I would measure resistance on all windings. If it is normal transformer at 50-60Hz you gonna have the low voltage side resistance under 5 ohms. High voltage side must have more turns on the winding so you expect that in the range of 1 Kohm. If you can't have this kind of measurements this means that this transformer is a high frequency transformer and you can't operate it as normal transformer. You need a high frequency switching flyback circuit to operate this. Also if the power was 1000 Watt i don't think this relatively small transformer can deliver 1000 watt on 50Hz, but can deliver maybe in the range of 20-40Khz. Also all measurements of our friend show "short circuit" = low resistance, and also any pair trip the mains!
All above statements lead to the conclusion that is a high frequency transformer.
