No - incorrect. Every input terminal, whether + or - will be at Vo/2.So for each + terminal of each op amp, the voltage is Vo/2, and for each negative terminal, the voltage will be a 0? Is that correct?
Yes, I am referring to the same point you named Va.Alright. So you said Va = Vo/2. Are you referring to the top left node?
