Analysis of this gyrator circuit (input impedance calculation)
dman
Joined Nov 6, 2008
Hi, the attached circuit picture is supposed to be a gyrator with an inductance of L = C.R1.R2. However, I am am having trouble deriving this equation.
What I've tried to do so far is calculate the input impedance Zin = Vin/Iin. But no value of Iin is giving me a Zin with an inductive impedance. What I'm mostly confused by is how the output of the top op-amp interacts with the opamp below it.
So far I have:
Top Op-amp:
e- = e+ = Vin
Therefore I1 = Vin/R
Bottom Op-amp:
e+ = e- = Vin
I2 = (Vout - e+)/R1 = (Vout - Vin)/R1 = Vin/R1
I'm not sure what I have to do to get a current in terms of the capacitor, and then calculate the full input impedance.
Thanks,
Jin
steveb
Joined Jul 3, 2008
2,436
Jin
It's definitely a little tricky to think about, but that formula looks correct using the simplified model of the OP-AMP. The relations can be worked out as follows:
Vin=0.5*Vout
Vout=I2*R1+Vin
I2=s*C1*(Vin-Vo) where Vo is the output voltage of the lower opamp
Vo=Vin-R2*Iin
If you substitute and do some algebra you get Vin/Iin=s*C1*R2*R1
This looks like the impedance of an inductor Xl=sL or L=C1*R2*R1
steveb
Joined Jul 3, 2008
2,436
I just realized something else about this circuit.
The input impedance Vin/Iin may not be strictly the correct thing to calculate.
You may instead want to calculate (Vout-Vin)/Iin since Vout and Vin are the identified terminals for connection. You get the same answer because Vout-Vin=Vin .
hgmjr
Joined Jan 28, 2005
9,027
The method I used involved introducing a resistor in series with the input signal and the terminal labeled Vin.
I obtained the same results as steveb by doing this. That answer being the virtual L = C1*R1*R2.
hgmjr
The Electrician
Joined Oct 9, 2007
2,986
Actually, I shouldn't have said: "The circuit can be redrawn as shown on this page", because the 2 opamps (along with 5 admittances) of the GIC can be rearranged topologically as shown in the attached .gif file.
I should have said, "...can be redrawn as one of the 24 possible GICs..."
The topology of the OP's circuit is designated B2D in the image.
An interesting question is, "why should any one topology be preferred over any other"?
If the OP is still following this thread, I would like to know where he got the problem circuit. Did it come from a text, and if so, what is the title of the text?
dman
Joined Nov 6, 2008
Thanks to all for your replies. I am able to get the correct inductance value now.
The circuit was part of our university electronics notes, under the heading "op amp applications," without any mathematical derivation. Actually, the notes are based on a book by Sedra & Smith.
As for whether to measure between the terminals Vin -> Vout, or just Vin -> Gnd, all it says on the matter is: "The circuit appears to the input to be an inductor to ground of a value L= CR1R2."
steveb
Joined Jul 3, 2008
2,436
That definitely makes more sense. It's unclear to me why they identify Vout as an output. It seems unnecessary to me, but maybe I'm missing something.
hgmjr
Joined Jan 28, 2005
9,027
Greetings dman,
Could you post your complete work in deriving your solution for the benefit of the other members that might be interested in seeing your analytical approach?
hgmjr
Wendy
Joined Mar 24, 2008
23,864
I didn't want to hijack this thread, so I posted this in the electronics chat forum.
I found gyrators facinating in college. I think I understood the math then, but it eludes me now. Such simple looking gadgets too.
hgmjr
Joined Jan 28, 2005
9,027
Here is my effort at analyzing the gyrator (inductor simulator).
Comments welcomed.
hgmjr
PS. This attachment has been edited to make the corrections that electrician identified.
The Electrician
Joined Oct 9, 2007
2,986
What software do you use to produce these documents? It gives good looking schematics and mathematical expressions.
One problem I see right off is that you've reversed the plus and minus inputs of A2.
Just after Eq. 1b and 3b you have the word "equally"; I think "equality" would be better.
hgmjr
Joined Jan 28, 2005
9,027
I use Microsoft WORD, PC-PAINT, and EAGLEPCB.
Thanks for reviewing the document. I will make the changes that you have indicated and repost.
Thanks,
hgmjr
JoeJester
Joined Apr 26, 2005
4,390
hgmjr,
May I suggest the next time you print it to the pdf, select the pdf printer properties and tell it you want b&w. I found that the color diagrams tend to lack the clarity as a b&w ... although it beats hand drawing the diagrams.
I've gone as far as printing the diagrams to pdf (b&w) before copy and pasting them into word.
hgmjr
Joined Jan 28, 2005
9,027
hgmjr,
Thanks for the suggestion. I will make sure to use b&w pdf settings in the future.
hgmjr
mikeska
Joined Feb 18, 2009
7
Hello, Dman
First off, sorry for posting on this old thread...
I was looking for some Gyrator circuits, and I found your derivation. Although you get the right expression for the input impedance, i'm not sure if the assumptions you made to proceed with the calculations are correct.
In your report, you mentioned this:
v feedback C---v
vin -- R2 --- opa + -------|- R1---- vin *2
- ---- vin
If the op-amps are assumed to be ideal, then no current will
flow into their terminals. All
the current must
flow from Vin, through R2, the capacitor, and R1.
Thus, Iin is the same as the current
flowing through R2 and is equal to
An opamp will have negligible current flowing into it's inputs (+ and - terminals). However, the opamp will most likely have current flowing from/into its output terminal.
So at the node connecting R2, C, and the Opamp Output, there will be a main current flowing into the opamp, and two branch currents of R2 and C adding together.
So then the correct observations before analysis would be that
1. There is a current flowing through both the R1, and the
feedback capacitor
2. There is a current flowing through the output resistor R2,
different from the current flowing through R1
3. The noninverting amp on the top stage has a gain of 2
I've attached my analysis of the circuit.
Which for some reason give the same result as when the assumption is made that the current into R2 and R1 is one and the same. What is happening here? lol ! Am I getting the math wrong?
Alright, i can smell it already, what am I doing wrong? :confused:
~mikeska
