TPS61088 - Design and testing
Dikxita
Joined Apr 22, 2024
27
I have used TPS61088 IC in one of my circuit design for boosting. This IC have a resistor divider circuit between Vout and FB pin as shown in the below circuit. Since I want an output of 5V, so with respect to below circuit using voltage divider formula in this case Vout =5V, R1= 769Kohms, Voltage at FB pin = 1.204(given in datasheet) i got R3= 243Kohms(using voltage divider formula that is Vout = (Vs*R2)/(R1+R2) by substituting Vout = 1.204V, Vs= 5V, R1=768Kohms as per below circuit). But when i practically measured after receiving designed board, Im getting 10V at Vout pin. Please help me to know why I'm getting10V instead of 5V.
Dikxita
Joined Apr 22, 2024
27
Where do V1, V2 and V3 connect?
About V1, V2, V3 no information is mentioned in datasheet. Hence I have just connected a 2pin connector to measure voltage at that point. Also i guess, V1 ,V2 ,V3 are the voltages mentioned under output voltage/output current column in the below table. I'm not sure though.
Ian0
Joined Aug 7, 2020
13,279
What voltage do you measure on the feedback pin?
If you have Vref (1.204V), then the circuit is functioning properly, and your voltage divider is wrong.
if you have a different voltage, then the circuit is not running properly.
What is your input voltage?
Dikxita
Joined Apr 22, 2024
27
I measured voltage at Fb pin ,its 1.22V
Plz check the table below its from TPS61088 datasheet. I have made MODE pin short to ground, hence its in PWM mode. So I'm getting max Vref voltage with respect to below table. So the circuit is working fine right and the problem is with voltage divider?
I'm using programmable DC power supply. I have set Vin = 3V and Iin = .5A
Ian0
Joined Aug 7, 2020
13,279
So your divider is the problem.
Output will be:
Vref*(1+R1/R2)
which gives 9V.
ericgibbs
Joined Jan 29, 2010
21,573
hi Dik,
I was following the App example that has the C2, 1000pF across the top resistor
The combination of the 49.9R and the 1000pF form a simple bypass filter.
E
Added: BW plot for the C1 effect.
Dikxita
Joined Apr 22, 2024
27
hi Dik,
E
Thanks Eric. I haven't made a provision for bypass filter. Is it important that I include? If i don't include will it affect my output and circuit?
Dikxita
Joined Apr 22, 2024
27
Yes, if you want 9Volts.
This is a good utility for calculating resistive dividers.
Thanks Ian. I'm still stuck at V1,V2,V3 and those unknown resistor(R3,R4 and R5) in the circuit. What's the purpose or intension of including V1,V2,V3 and R3,R4 ,R5? Could please help me to understand?
ericgibbs
Joined Jan 29, 2010
21,573
Hi D,
By bypassing the 768K resistor with the 1000pF the response to high going Vout spikes, it will increase the Vfb response, thus pull down the Vout faster to the desired Vout.
Personally, I would not include the 49.9R and 1nF
E
