TPS54302 circuitry for 12V output
darkmatter_2001
Joined Sep 13, 2023
Hi ppl,
Can i use the below circuitry as 12V output, i tried simulating in proteus 8.11 but i think it is not supported so i didn't get output and Tina-Ti doesn't have the IC i'm using so if anybody can suggest as to where can i simulate any circuitry without platform hinderance or atleast simulate below circuit.
Thank you
wayneh
Joined Sep 9, 2010
18,104
Where did the circuit come from?
If you can believe what it says, it does indeed provide a regulated 12V output.
darkmatter_2001
Joined Sep 13, 2023
Thank you for your reply,
I got the circuit from data sheet of TPS54302 IC, but the additional add-on i.e series combination of inductors of values 2x6.8uH and a 3.3uH to get a resultant inductance above 15uH is customized. Can i practically get 12V by the series combination of inductors?
