TP4056 PROTECTION BOARD - MANUFACTURE ERROR
longpole001
Joined Sep 16, 2014
62
Hi guys i have had found an issue with ALL board purchased on the latest batch ( 100 units ) of tp4056 protection , from ebay , aliexpress
It appear that the 100R( R5) resistor and the 1K0 (R6) have been swapped on the pcb on the these style of boards, and from what i can see will not function correctly
This appears to be a common fault looking at any google picture on the web for this design PCB
Also attached is the circuit and another pcb layout which has the components correctly mounted
Not sure if others have found this prior , but simple search of web did not show it
Please comment and check your boards if you have this design
Cheers
longpole001
Joined Sep 16, 2014
62
This is serious stuff up on this module -
as can be confirmed in the attached datasheet of the DW01A , The CS input has now a 100R (R6) , which sets the voltage for charger detect / over current / short circuit
With VCC now having 1k0 ( R5) in place instead of 100R this reduces the voltage to the input of the chip and as such the voltage comparitor inputs on the input voltage
YOU SHOULD SWAP THESE RESISTORS
THIS MANUFACTURE ERROR SEEMS TO APPEAR CURRENTLY ON EVERY MODULE MADE USING THIS DESIGN LAYOUT
JohnInTX
Joined Jun 26, 2012
4,787
Yeah, well... that can happen with 'copy-that' manufacturing. But think of the money you're saving!
Sorry you got bit but those are the risks using eBay and Alibaba knock-offs. Thanks for the info, though.
JohnInTX
Joined Jun 26, 2012
4,787
LOL , its not an issue for the 100units i have , but its the millions that are out there that have the problem
It's good that you posted that even if it invited some unwelcome criticism. Sorry. I've been in the business long enough to remember when manufacturing meant reliability and accountability. Now, for too many, it's just lowest possible cost. Not a bad thing on the surface but besides the specific problem you identify here, when enough buyers bite on the super-cheap stuff, legitimate guys can't compete then shut down. That makes all of us hostage to the junk-miesters. For those of us who still build things, it's hard to find reliable suppliers and after paying what it takes to make it right, to compete. Glad I'm retiring.
Good luck!
ebp
Joined Feb 8, 2018
2,332
If you look at the datasheet for the protection chip, the maximum Vcc current is 6 µA, so using 1k instead of 100 ohms will only change the voltage at the Vcc pin by 5.4 mV, which is a relatively small increase in the +50 mV maximum spec error (±50 mV) for overcharge voltage. Typical Icc is 3 µA, so the typical increase in overcharge voltage would be only 2.7 mV. Using 100 ohms instead of 1k at the CS pin compromises the latch-up immunity under a specific condition (battery over-discharged when the charger is connected). Overall, this slightly degrades overcharge protection for the battery (necessary when the charger chip loses its brain) and renders the protection chip more vulnerable to latch-up, It does not entirely prevent the chip from doing its job, though latchup might be destructive.
Pin 1 of the protection chip is misidentified in the annotated photo at #1 - it is at the other end on the same side.
longpole001
Joined Sep 16, 2014
62
too many sellers ,
i contacted the seller , he said "sorry but our stock all same , You want buy more , how many "
just stay away from this pcb layout , as any produced to date will have this problem
this does not negate that your still dealing with TP4056 clone ,(4056E) so try and get boards with the TC4056A chip , which now is becoming the main alternative to clones on modules , at least its an equivalent , has not been cloned so far,
the other pcb i listed at top of page seems fine and has no resistor placement error
cheers
Nasib
Joined Oct 23, 2019
Hi! i have developed a boar where this whole circuit is mounted... I realice that the DW01A IC is consuming 1.5mA!!! .. wtf...and i have used a 100ohm res in the vcc pin...have any of you experiment this issue too ?
Thnx!
KeithWalker
Joined Jul 10, 2017
3,627
Cheers
View attachment 153995View attachment 153996
Thanks for the heads up. I checked the ones I have and they are OK but I will be on the lookout next time I order.
Regards,
Keith
