Reverse Polarity protection for 18650 battery charger (tp4056)
cyberdyne
Joined Jan 29, 2019
I need advise on best value components for this Reverse Polarity protection schematic (pictured).
source.
The original author just used what he had laying around,
>2N2907A
>IRL2203N
as i will be buying everything new, that gives me a lot of options.
Requirements:
  • 18650's charge up to 4.2 volts
  • Max continuous 1000mA (1A)
i need to make 20 of these for my charging board,
so i dont want to waste money over engineering it.
Cheapest reliable parts will be fine.
im new to electronics & totally confused on how to select the right transistors?
Also do i need to be worried about the volt drop over the mosfet?
38,948
The BJT can be just about any PNP such as the common 2N3906.
The N-MOSFET can be any logic level type (with a Vgs threshold of <2V) that has an ON resistance of ≤10mΩ.
Yes, you need to be concerned about the voltage drop across the MOSFET.
10mΩ On resistance will give a maximum voltage drop of 10mV @ 1A.
cyberdyne
Joined Jan 29, 2019
Hey Thanks crutschow.
I just placed an order for the 50x 2N3906 fro $1.
After searching on mouser.com to find a MOSFET options that met the specs you listed, i checked eBay for price.
I cant seem to find anything cheaper than what the original guy used "IRL2203N" @ $4.28 for 10pcs.
Good price?
Do you have a formula or rule i can use to work out for myself in the future? or a video guide or something?
I've also been wondering the best way to join them without a pcb...?
