My lipo battery is hard-wired into my circuit. The battery itself has a DW01A battery protection IC on it. Here's what I see happen.
* The circuit running on battery power (no USB) runs its voltage down to 2.4 V when the overdischarge protection kicks in. The BAT+ and GND in my schematic at that point read 0V because the DW01A mounted on the battery itself opened the circuit
* I then plug in USB power, supplying the TP4056 with power which I expect to start the battery charging process
* The battery charging doesn't start
One of my question is why? I think it's one of two things or both:
Idea 1: The circuit to the battery is still open because the battery itself hasn't recovered back to the overdischarge release voltage of 2.9-3.1V. Chemically speaking it just may not which is concerning because then the battery itself couldn't ever recover given its hardwired in.
Idea 2: The TP4056 can't recover a battery that is < 3.0 which is the trickle charge threshold voltage.
So what do I do to resolve this? I only have a few ideas:
1) Implement an over-discharge circuit myself that interrupts at 3.1V which is greater than 3.0 which is the claimed maximum of the trickle charge threshold voltage of the TP4056. Further voltage drop below 3.1 would be minimal (DW01A and other IC leakage currents), when plugged in the TP4056 would have a closed circuit to work with since the DW01A wouldn't be in overdischarge mode, and the TP4056 will begin charging since it's higher than its trickle charge threshold voltage.
2) I have no other ideas lol.
What should I do here?
Any example circuits I can look at for this problem?
