Hi Wendy, so with this schematic, it looks like the jumpers will work directly with your 256 LED board that you posted? Is that correct?
That was indeed the intent. Eventually I'll turn this into a PCB, but it takes longer to build em than to draw them.
I like to draw concept circuits. I also have a variable power supply, a 100W Class D Audio amp, and several other projects drawn and on the back burner over the years.
A power on monostable (the MOSFET is not critical)...
Minor revision on 16 output controller (look at the power up reset)...
New version of Stream, breadboarded with 20 blue LED's using low side drive & blue flickering LED for signal
source. A comparator is used for signal shifting. Led current about 5 mA & quite visible. Out of time for now.View attachment 100164
What about the ocher questions.The diodes are not important, it can be almost any device. I lucked into a large bunch of 1N4007 a long time ago, or it can be 1N918 / 1N4484s.
The output of the monostable is the timed power, per your request. I didn't bother to show the ground connection, the output of the MOSFET is power.
Look above the caps, where it defines the circle as the power supply connection and the voltages. They are filter caps for the chips, something every circuit should have.
Decoupling or Bypass Capacitors, Why?
awesome cant wait. I did download the post 100 but if you have a new 1 ill waitSee post #100.
It is out of date, I have a new image for the actual PCB layout.
Hi Wendy, so the output of the monostable supplies the power to pin 16 of the 4017's? Just want to make sure. What about R4, C2, and R6? Also output of the monostable? ThanksSee post #100.
