I have been fiddling with an off the shelf 1000W, 48 V, 20 Amp ZVS driver with a 5 mm copper work coil and powered by a MeanWell RSP-1000-48. The medium I'm heating is an iron pipe (due to it's highly ferromagnetic properties).
Tried using litz wire instead of copper coil, but with limited results. However as I understand it a litz wire should be the preferred type of heating "coil". The diameter of copper tube and litz wire coil is identical.
The first testing with the off the shelf ZVS drive I notices quite a heat loss from within the heating coil. Then I completely insulated the iron pipe with an aero gel matting and am now retaining all the heat.
My main question is: If I were to double the size of the ZVS driver to a 2kW, 48V 20 amp and likewise have a 2kW 48V power supply .....would I be able to heat the Iron pipe twice as fast?
