Double Tail Comparator-( Help me fix the issue)
Aryan_Pisupati
Joined Mar 30, 2026
I have to design a double tail comparator for a 1GHz frequency and difference in voltage of 5mV. I should also do the pre and post layout simulation in 180nm. optimized your design for low delay. using Cadence Virtuoso.
The problem I'm facing is one of the output(Outm) is correct and is able to sweep from 0V to1.8V, but not the other output (Outp).
How do i fix it whats wrong with my schematic?
How do I get Outp to negate and sweep from 0V to 1.8V?
MOD NOTE: Moved to Homework Help.
Rf300
Joined Apr 18, 2025
127
According to your description (180 nm ASIC-design, using Cadence Virtuoso) I assume this is not a hobby or DIY-project but a commercial one. Therefore commercial support rates will apply.
drjohsmith
Joined Dec 13, 2021
1,661
Is this "homework"
