The TL431 doesn't need much load capacitance to make it oscillate!I still don't think we have the correct circuit. the pot will now adjust the output voltage, but the output looks horrible!!
200 mV of output ripple is not a supply I would use. I still can't figure out how to get 12V of output.
Sure -- no problemhi Papa,
Any chance of having a look over your asc file.
E
The purpose of this exercise is understanding the circuit that the OP thinks he has. I have little or no interest in speculative designs for an unknown purpose.Try moving the capacitor from across the TL531 to from output to input. That will slow it down.
I think people should review the datasheet, and the TP needs to check their idea of the schematic against the suggested versions in the datasheet- it could be, they are using one of the typical applications shown in the datasheet.I still don't think we have the correct circuit. the pot will now adjust the output voltage, but the output looks horrible!!
Well, that is progress. At least we are able to duplicate the TS observations. In my previous post, I added the input capacitor, C3, to see if it made a difference -- it did not. I tried another LM317 model in the circuit of post#20, and it produces something closer to the results of @ericgibbs. So it looks like not all LM317 models are created equally. I don't have the BD244A, but the transistor model does not appear to be the critical factor.hi Papa,
The asc file you posted was not the same as your post #20.
So I edited your asc file to suit the posted version.
Used my LM317 and Pot models and a BD244A [don't have 2N5884]
This is what LTS shows.
E
2 Volts P-P ripple on the 11.7 volt output. Was that supposed to be an improvement?hi Papa,
I know it's a modification, but move C1, 100n to the Pot wiper connection to 0v.
E
Thanks -- I'm sure it will be.hi Papa,
Is this any help.?
E
Here is a functional block diagram of the TL431. As you can see there is an amplifier with a 2.5V reference and no feedback to limit the gain, but when the REF pin is above the reference voltage the transistor turns on and provides a low impedance path from cathode to anode. that is why it is referred to as a shunt regulator..Interesting...
I will get the exact make/model of the 317 in the circuit as I would bet there are internal differences that might matter..
Im sure that is true for the TL431AC too.
So remember the actual behavior measured is a bit different then what this looks like so far. It has a pronounced 100mV swatooth oscillation with no load and around 50-100mA of load promptly snaps to 3mV pk-pk of a wideband zener like noise. This stable, but noisy, performance *seems* fairly stable.
I will poke more at it soon... I have been hit with boring work things but will get back to this.
I still dont understand those high values on the adj side of the TL431. Why would this circuit need gain on the TL431 ? If thats gain that is.
