Thank you to @ericgibbs and the TS for motivating me to hang onto this problem like a pit bull with a meaty bone. Sometimes we need that extra kick to motivate the use of the "little grey cells".
Right. That is the insufficient load current scenario. Interesting and true, but not necessarily part of this particular thread IMHO. The TS was interested in understanding how the circuit, that was represented by a product that he had already purchased, was actually working. Multiple simulations without models that duplicated his exact situation were attempted with limited success. It took some digging to uncover what might actually be going on. All in all, for this application, I would be looking for an alternate solution with particular specifications for current voltage and voltage ripple.Remove Q1 and increase R5 to 500R. And you will see that this circuit will oscillate without Q1 (enable .tran 50m startup ).
I'll give that a try and get back to you.But we can make the circuit stable just by moving the bottom leg of a C3 to Vref.
Add some ESR, 0.1Ω or less to the output cap.I still think the ripple is too much for an allegedly stable linear regulator.
Yes, it is still a very bad design. I don't like it at all.This might confirm that the product purchased by the TS might suffer from one or more design flaws if he can observe and measure noticeable amounts of voltage and or current ripple on the output.
If I find some time I will try to check it the day after tomorrow on the breadboard.We can only wonder if his circuit and any of the simulations we have tried are related in a meaningful way.
NJW0302G PNP Transistor
.MODEL NJW0302G pnp
+IS=5.16751e-16 BF=114.657 NF=0.895716 VAF=50.2189
+IKF=6.409 ISE=3.9641e-15 NE=4 BR=1.47167
+NR=0.923324 VAR=255.567 IKR=6.34299 ISC=3.96408e-15
+NC=2.82194 RB=2.66347 IRB=0.1 RBM=2.0828
+RE=0.0001 RC=0.0652395 XTB=1.45322 XTI=1.08126
+EG=1.05 CJE=2.14504e-09 VJE=0.4 MJE=0.376227
+TF=2.16864e-09 XTF=1000 VTF=843.737 ITF=501.348
+CJC=5e-10 VJC=0.95 MJC=0.251547 XCJC=1
+FC=0.8 CJS=0 VJS=0.75 MJS=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
But you already have the TL431 model.TL431AC, if anybody thinks this might be relevant
Thanks for the transistor modelBut you already have the TL431 model.
Irrelevant in this case.but not one that is specifically labeled "TL431AC",
Hard to say. Do you have original design schematics? So that we can compare and see?. Could they have revised the design in the meantime, or did the OP get a bad clone of the original, which seems to be from Weilang Audio/BRZHifi?
