Bear in mind the maximum powwer dissipation in the chip so the maximum output current will depend on your supply voltage.I can push it to max without it going up in smoke.
I am working through the TI Op Amp Handbook and notice the resistor is marked R(sub)L, load resistor. The resistor in this example is the load as well as the feedback. No idea of how this may actually be used even though they gave some examples that I am not familiar with. Simply an exercise of the presented theory. Not finding the max output current the PDF section for the TL071C (it was in the section for the TL071H so I hope it carries over to the C) I did not have a clue as to what the max output current might be for this Op Amp experiment to design for. And yes, anything can be smoked if overstressed. Which I am trying to avoid! Also note the I have moved on from the "Antique" 741 to a more modern design.Your inverting amplifier has no load (it is not a constant current source circuit) so you are measuring the current in its feedback resistor. If the feedback resistance is low then all of its output current will be in it, instead of in the load.
Post #1 does not have a voltage follower and does not produce constant current. Instead it is a simple inverting amplifier. The ratio of the resistors determines its gain or loss.In this instance (post #1), it is a modified voltage follower with a load in the feedback loop to give constant current. So there is no amplification. Just illustrating a modification of the voltage follower. Unless I've missed something? Hopefully I can find time today to breadboard it. Built and played with it a bit in LTS.
Yes, that is the conclusion that I came to and scratched my head a bit about it. They mention two examples of usage " can serve as a linear meter amplifier or deflection coil driver". Just woke up and not completely coherent as yet, yes, it IS an inverted amp (not voltage follower my bad) example. So the idea here is the induced current is the feed, Irregardless of the load, is the current across the load?The current in the input resistor produces exactly the same current in the feedback resistor. Then the opamp is not needed,
