"TIP" Transistor Models For LTSpice
RRRRSSSS
Joined Jun 16, 2023
128
Hi:
Can anyone tell me where I would find reliable Spice models for all the "TIP" series of power
transistors and darlingtons?
RS
ericgibbs
Joined Jan 29, 2010
21,569
hi RRSs,
I don't have a single file that contains all the TIP series, but a number of individual models, if you could say which TIP types are of interest, I will try to find them.
E
RRRRSSSS
Joined Jun 16, 2023
128
hi RRSs,
E
Hi E:
TIP29 , TIP30
TIP120 series darlingtons
I guess some of these might be obsolete but I can get some of these cheap from a local vendor
for experimental purposes.
RS
ericgibbs
Joined Jan 29, 2010
21,569
hi RRSS,
If you want to try, you could get the TIP29/30 datasheets.
Open up the NPN lib and copy and paste back a copy of one of the modelled TIP transistors, rename it to say TIP29 and then modify the model parameters by referring to the TIP29 datasheet.
Not an easy task, but I have done it for some other types of models.
E
RRRRSSSS
Joined Jun 16, 2023
128
hi RRSS,
E
thanks E
I found a bunch of TIP models. Don't know if they are good yet. Here is the link.
https://www2.seas.gwu.edu/~ece20/spec_sheets/parts/spice_libs/TIP31A/pwrbjt.lib
RS
