this is to design a limiter circuit.. anyone know give your ideas...
Thilzz
Joined Jan 20, 2023
the requirements are,
The input signal of the limiter Vin is a sinewave having a maximum amplitude of 10V and a frequency of 60Hz.
The input signal Vin is fed to the circuit through a resistor 500 ohm. and if Vin<=-9v , Vout = 10v and -9v<=Vin<=6v , 0v<=Vout<=10v and Vin>=6v , Vout = 10v are the needful factors for the limmiter. s
o I should use only the following components
-a Diodes with a constant voltage drop of 0.7V.
- Zener diode operating in the reverse bias region with Vz=4v at Iz = 1mA , and rz = 1ohm.
- Resistor (having any value)
- DC voltage sources with a voltage between -0.7V and +0.7V.
How to design the circuit using these components. the circuit must be easy to understand and give me a diagram for the circuit
Ian0
Joined Aug 7, 2020
13,279
There are various different meanings for the term "limiter" in electronics. It could be an audio limiter that reduces the volume of the signal, or a voltage limiter that prevents harm to other components.
And also, the shopping list of requirements make it look a lot like homework.
Thilzz
Joined Jan 20, 2023
this is for voltage limiter circuit
38,825
Since this appears to be a learning experience, you should show us your approach to solving the problem.
If we just give you the circuit, you won't learn much.
