thanks for the reply
the original is a PTC which measures zero ohms @25deg ( room temp )
when it is heated and exceeds 500ohms.. the charger turns off ( temp? )
these results are obtained by experimenting with an identical thermistor
from a similar device
if a fuse type would fit this criteria.. what sort of spec
would i be looking for
thanks again
