I am a student in power electronic filed. When I design PCB and calculate the junction temperature of MOSFET, I am very confused about the thermal design question.
My PCB design is here: (in the middle of the figure) : three MOSFETs in parallel, so 12 MOSFETs(Rthj-c=0.4 from datasheet) in one converter converter by one TIM pad (Rtim=0.62 from datasheet), we have four converter in one cold plate, so 48 MOSFETs on the single cold plate.
I read some documents, it says we should calculate based on single MOSFET like this: (the top in the figure): Pv*(Rthj-c+Rtim+RHA)=Ta-Tj. If we just have one mosfet I agree with it. But actually we have 48 MOSFETs and 4 Tims! So in my opinion, I should calculate in the bottom of the figure. I think the Rthj-c should be reduced because we have 48 Rthj-c to parallel, Rtim should be also changed because the contact area will be smaller than TIM aera. But that's so complicated, and the results looks wrong, RHA will be a negative value!
I am so confused about this. I am working in
a project, my colleages calculate them based on single MOSFET, becuase they said it is independent. But I am thinking we do have 48 MOSFETs, could we use Rthj-c=0.4? and the contact aera of TIMpad is small, could we use Rtim=0.62?
I would appreciate it if someone could help me! Thanks so much!
a project, my colleages calculate them based on single MOSFET, becuase they said it is independent. But I am thinking we do have 48 MOSFETs, could we use Rthj-c=0.4? and the contact aera of TIMpad is small, could we use Rtim=0.62?I would appreciate it if someone could help me! Thanks so much!
