“And all else is the work of man”....
Because we insist on having a definition for something that is not definable or that even has a true, rational relationship, we have contrived arithmetical expressions to describe the clinically insane.
22 units as a circumference and 7 units for a diameter are truly not numbers that are perfectly related as another number.
So we write this as a numerical approximation. The ratio of integers is most closely approximated to 3, a true number that God gave us along with integers that make up the contrived ratio of 22 to 7. It doesn’t “add up,” which is another way of saying “make sense,” because all arithmetic is unary addition in disguise.
In 22 / 7, we have a nonsensical garbage dump quantity left over that is not a number. It’s a “state of undefinable, interminable insanity,”also known as Room E409 at Cantor’s insane asylum. Irrational = insane. Insane = Jihad. Opposite of God’s clean, innocent, orderly, beautiful integer invention is the machinating mind of a race of grotesque, addicted, violent, irrational, competitive and ultimately rotting and dying creatures on their hind legs. Of course, that’s the hand we’re dealt, and we’ve made the world more automated and inhabitable, by inventing technology that is convenient, but at the same time senseless, filling our minds with plenty of irrationality and making us less truly unified and often miserable. The remainder in that division is not an independent godly number, it’s the “numeric expression of irrational, unterminating dependency, addiction, and lunacy.”
Similar to sqrt(2). There is no TRUE relationship between the squares and the diagonal, though we so desperately want there to be, and “it’s close enough.” So we invented, yet again, an arithmetic expression to discretize or number the non-numeric.
Same is true for sqrt(-1). That is a contrivance whose solution is not a true, or real, number whatsoever. It’s “i” for imaginary. Because it’s not based in how reality works.
We’re bent on putting infinitudes into finitudes.
So I take it back. There is no ℝ. There is only God’s beautiful integers, and Man’s numeric contrivances and PROCESSES to relate God’s numbers that don’t have any true relationship, and are largely found in ℝ,but a workable one, however, while we’re dying. To compare the cardinality of ℝ to ℕ, as if ℝ is a set of comparable stand alone numbers, is the height of the blasphemy of our Dahmer’d minds.
So congratulations... unary and “f*ck you, Rene” FTW (with all due respect). The line should have been called U for Unreal.
To create a true ToE based on the way things are, we need to disabuse ourselves of man-made machinations and consider the most elemental, independent phenomena of Godnecker first, before we fold in numeric approximation processes.
