Hey!! Anyone can help me out on the circuit to get the inverted pulse output from a one shot monostable 555 timer circuit. The circuit seems to be correct but still I am not getting the desired output of 12 volts which drops to gnd for a few seconds and then again raised to 12 volts instead a 7 volt raise is received. I need to drive a 12 volts latch relay with the output. Will require 2 such circuits for dual coil latch set and reset coils. Help is really appreciated, thanks!!
Mod: adjusted your image.
