Huh?Power Source is 6V becouse equivalent total resistence is 6W=6Vx1A.
I have some inkling of what the underlying problem is, namely find the values of the six resistors such that each resistor is dissipating 1 W, but I'm not in the mood to guess or, more to the point, to do anything with just a guess.R1 is 1 Ohm, VR1 is 1V therfore VR2=VR3=2.5V I23=0.4A, R2=R3=6.25 Ohm. I4=I1-I23=0.6A V4=1.67A R4=2.78 Ohm. I5=I6=I4/2=0.3A . R5=R6=1W / I5^2=11.1 Ohm
In the picture the simbols means: Resistence from R1 to R6 dissipate all 1W each. Find resistence values from R1 to R6 (R8 is a mistake sorry!)The notation makes no sense. R1 divided by R6 is a dimensionless number. It is not a power.
And if, somehow, R1 divided by R6 is a power, how can R1 divided by R8 now somehow be a resistance?
You don't even show an R8.
Please explain what any of this means and what the problem is that you are trying to solve.
So my guess was correct. Thanks for the clarification.In the picture the simbols means: Resistence from R1 to R6 dissipate all 1W each. Find resistence values from R1 to R6 (R8 is a mistake sorry!)
Welcome to AAC.Tricky simple circuits in DC to help understand Power meaning
Even if your results are correct, the reasoning you use is not adequately supported (though I suspect your reasoning itself was adequate).Power Source is 6V becouse equivalent total resistence is 6W=6Vx1A. R1 is 1 Ohm, VR1 is 1V therfore VR2=VR3=2.5V I23=0.4A, R2=R3=6.25 Ohm. I4=I1-I23=0.6A V4=1.67A R4=2.78 Ohm. I5=I6=I4/2=0.3A . R5=R6=1W / I5^2=11.1 Ohm
