MisterBill2
- Joined Jan 23, 2018
- 28,243
A couple of years ago I got an "emergency" call about a very loud noise in the house of a client/friend. It was scaring the cats quite a lot. So I went to the house and certainly the noise was very loud, much louder than normal conversation. It seemed to be loudest near the furnace, so I switched the furnace off. No change. So I went to the breaker panel and switched the circuits off one at a time. No change, so I switched off the main No change! So the sound was not caused by anything electrical. Walked back to the furnace, felt it vibrating at the noise frequency, about 300 Hz, my estimate. Felt around, where was the vibration strongest? On the hot air plenum near the humidifier. Much stronger. Closed off the water valve to the humidifier, half way off the noise stopped. Opened the valve, the noise started again. Did that twice to verify it.
So I left the humidifier water valve mostly closed, 2 years and no recurrence. Who would suspect "water hammer" in a 1/4 inch tube to a humidifier??
My point being that perhaps the noise is not electrical, but coupled into the house from some other, non-electrical cause.
Depending on where the TS lives, it could be a water main flow noise or even a gas main flow noise. That would explain it being everywhere and not trackable.
One other possibility is that it is a mechanical vibration from the inverters associated with that nearby solar power array.
That could explain why it is a challenge to isolate.
