testing MPU (Magnetic pickup unit)
qitara
Joined Jan 18, 2013
112
The sensor is used to measure a shaft rotation speed. The MPU is installed on a bracket and takes the readings from the gear teath on the shaft.
I am able to take the MPU apart from the bracket to test it but the question is how do i test it ?.
qitara
Joined Jan 18, 2013
112
Turn it on and see if it works?
I'm not trying to give flip answers, but there's no way to give a detailed answer without more details of the situation. Power source? Model number? Sensor details? Photo?
The MPU model number is (3034572). It is directly connected to an input/output card on a micro controller board that works as a PI controller. I am able to replace the sensor and go ahead but what i want to know is a way to test these MPU's ?
30,825
If this is the type similar to used in automotive timing that measure flywheel crank teeth, then they are usually NPN open collector output, if so you need to place a 1k resistor from output to +vdc.
Then use a piece of ferrous metal to pass in front and measure the volt drop across the resistor.
The threaded barrel type also work this way.
Honeywell make one 1GT101DC
qitara
Joined Jan 18, 2013
112
Thanks for the replay Max.
If i am right a magnetic pickup is just a coil coiled around a small magnet ?
30,825
Often a little more to, it usually consists of a hall sensing circuit with transistor output, so usually some on board electronics.
There is also non-ferrous detector types.
