Monitor the output while playing a strong magnet across the sensor (observing correct magnetic polarity, of course)...Hi guys
What is the best way to test a magnetic pickup sensor ?.
The MPU model number is (3034572). It is directly connected to an input/output card on a micro controller board that works as a PI controller. I am able to replace the sensor and go ahead but what i want to know is a way to test these MPU's ?Turn it on and see if it works?
I'm not trying to give flip answers, but there's no way to give a detailed answer without more details of the situation. Power source? Model number? Sensor details? Photo?
If this is the type similar to used in automotive timing that measure flywheel crank teeth, then they are usually NPN open collector output, if so you need to place a 1k resistor from output to +vdc.The sensor is used to measure a shaft rotation speed. The MPU is installed on a bracket and takes the readings from the gear teath on the shaft.
I am able to take the MPU apart from the bracket to test it but the question is how do i test it ?.
Thanks for the replay Max.If this is the type similar to used in automotive timing that measure flywheel crank teeth, then they are usually NPN open collector output, if so you need to place a 1k resistor from output to +vdc.
Then use a piece of ferrous metal to pass in front and measure the volt drop across the resistor.
The threaded barrel type also work this way.
Honeywell make one 1GT101DC
| K | Testing Ni-Cads used in solar lights | General Electronics Chat | 19 | |
| L | Preparation for semiconductor testing course admission test | Jobs & Career Advising | 0 | |
| V | USB failures while testing | Test & Measurement | 4 | |
| Y | testing VNA cables for proper funtioning | PCB Layout , EDA & Simulations | 2 | |
Testing LEDs on a PCB | Technical Repair | 17 |
