I have a new digital camera arriving next week and will post some photos and the general settings I used to get those photos after some trial and error.
It should be if you are on the same North American continent that I am and if in the US your residence is wired correctly in accordance with the NEC (National Electric Code).I suppose what I need to do is test to see if the Neutral in my home is in fact bonded to Ground (which I believe it should be, unlike my generators).
What you are seeing and as Dick affirms is really pretty common. Seeing slightly flattened tops and bottoms as seen below is what I believe you are getting at:The waveform I got from this test on my House AC showed a minor flat spot on the peaks and I'm wondering if this indicates the condition he spoke of where the peaks of the sine wave has possibly been chopped a bit from voltage loss due to his concern......I'm not sure but it seems plausible to me.
I have the same. The only lines switched are L1 and L2 the 240 VAC. The Ground and Neutral are just passed through from the generator. to my mains power panel. That is where Ground and Neutral are bonded. I use an automatic transfer but it matters not as in any transfer I have seen only L1 and L2 are switched. I don't quite see where having a mains transfer switch should pose a problem or complicate anything.I have a power transfer switch in my home I should mention which allows me to disconnect the house AC from the outside Line for connecting a generator, so this could complicate things a bit.
| V | USB failures while testing | Test & Measurement | 1 | |
| Y | testing VNA cables for proper funtioning | PCB Layout , EDA & Simulations | 2 | |
Testing LEDs on a PCB | Technical Repair | 17 | |
| Y | infiniBand Layer 1 specifications testing question | Test & Measurement | 2 | |
| J | Testing my telephone line. | General Electronics Chat | 9 |
