This must be the must frustrating project ever!
So far i tried:
2 secondary coils, a 812 turn in 30g wire and 25.4 cm long in a 3.3 cm of diameter pvc pipe, and the one in the picture is 316 turns in a 2.1 cm diameter pvc pipe and 10.9 cm long.
3 primary coils, a spiral calculated in javatc and two cilindricals changing orientation for the turns, 4 and 6 turns, and NADA (nothing).
I have the TIC31C transistor and there you have a schematics for my circuit, but i have read all i can just to replicate successful circuits and NADA, 47 Kohm resistor, LED, when i pull the transistor out the LED turns on, transistor never hot, like chilling, not working.
I used to work on a protoboard clamping all with those color jaws with wire and NADA, so i placed the circuit in a Perforated coper plate and 2X9 Volt in parallel batteries
So i need help im going krazy.
Thanks for your time.
So far i tried:
